4l80e unplugged?
Old Dec 16, 2019 | 06:11 PM
Pylavigne74's Avatar
Default 4l80e unplugged?
Can i run my own rebuilt 4l80e unplugged to see any issue or leaks and read pressures? I just finished a swap th350 to a 4l80e . I will install all the wiring later, easy tcu whit paddle shifter😎3500 stall torque converter, Jake's recalibration kit...what happens when it's not connected?
thanks
Old Dec 17, 2019 | 01:37 AM
91 Z28's Avatar
thanks
I believe your only gonna have reverse and 3rd gear. Torque converter clutch won't work either. The transmission needs power to work properly
Old Dec 17, 2019 | 07:03 AM
MaroonMonsterLS1's Avatar
unplugged 4l80e will be MAX line pressure and only 2nd gear. No TCC.
Old Dec 17, 2019 | 11:16 AM
Does it can damage the trans ? I will just check on the lift ,no road test... thanks
Old Dec 17, 2019 | 03:20 PM
what exactly are you trying to check on the lift?
Old Dec 18, 2019 | 10:44 AM
I would like To check if i have well assembled the transmission. I did a complete dismantling and change worn parts only... i would like to know if i have to remove the trans. (Hope not)...
install all the wiring will take me a lot of hour for a clean installation ... im just curious now that everything mecanical is done...it on my lift for all the winter...
Old Dec 18, 2019 | 01:58 PM
all you will know on the lift is if you have 2nd gear and reverse
