Rossler th400 with brake, no reverse?
Old Jan 25, 2020 | 02:11 PM
Blknova's Avatar
Question Rossler th400 with brake, no reverse?
Hey guys, I’v run in to an issue and would like to see if anybody has any ideas. I have a brand new Rossler th400 Terminator 3 with their Direct Port transbrake. The transbrake has a black and red wire coming out of it. Black wire is to ground. A good solid ground. Red wire has 12v power to it. The fitting with the wires are coming out of the transmission case itself and not the pan. I finally got the car fired up yesterday. I have an LS motor with Holley computer so we just got a base tune sent in yesterday. The transmission will move the car forward, but not reverse. The transbrake button does nothing in Reverse, neutral, or first gear. Switch is good. Can someone give me some ideas what I’m missing here? Rossler not open til Monday so can’t ask them at the moment.
Old Jan 25, 2020 | 10:56 PM
vorteciroc's Avatar
Can you give is any more details about the transmission/ valve-body/ trans-brake...
Model numbers or instructions? Forward or reverse shift pattern? With or without engine braking, and in which gears?
Some Trans-Brake Valve-bodies do require solenoid activation for reverse, and some do not.
You are going to check if it shifts third gear properly and "Manual low/ first gear"
Old Jan 27, 2020 | 11:29 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
Sounds like the solenoid isn't activating to me. Have you put a test light on it to make sure you have power at the wires going into the case? If so I would check power at the wiring going into the solenoid in the pan next.
-Dalton
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Jan 27, 2020 | 06:49 PM
Blknova's Avatar
Got it sorted today. This valve body requires neutral position on the shifter for reverse but also had 2 broken wire connectors that were plugging in to the transbrake plug. Crimper tool cut the wire right through. I’m happy to say I now have reverse and a working transbrake
Old Feb 10, 2020 | 12:37 AM
JCS94's Avatar
by this you mean put the car in neutral and press the trans brake button to reverse correct? I have a termi 2.5 in my Firebird and getting ready to get the thing ready to drive and wanted to verify this before thinking I don’t have reverse haha
Old Feb 10, 2020 | 07:31 AM
Blknova's Avatar
In short yes that is correct. Atleast for MY valve body which is the direct port. I hooked up a toggle switch on my shifter cover for reverse but Tranbrake button will do it as well.
