Stock 4L60E 99 T/A FYI
Old Feb 14, 2020 | 12:15 AM
br549's Avatar
Default Stock 4L60E 99 T/A FYI
I was previously having an issue with my torque converter not wanting to stay locked out, it was randomly disengaging after I replaced the brake booster. apparently the brake switch was not tight enough to the pedal. first I disconnected the battery so I wouldn't get any crazy codes then I disconnected all the plugs going to the brake switch and rotated it clockwise untill it was good and snug up to the brake pedal. I have not had any torque converter lock-out issues since I done this a month ago, so if you're having this kind of issue make absolutely sure that the switch is good and tight. I will upload some pics in the morning.
