IDing a 4l60E (engine family)
Old Feb 19, 2020 | 09:36 AM
forcd ind's Avatar
Default IDing a 4l60E (engine family)
I picked up an engine and trans, sup to be a 5.3, if its the orig trans hoping the tag
will reveal the engine family. The 4 large letters are OCHD-the O would be the year,
obs 2000, has the 12 o clock bolt hole. Not sure what the rest mean, conflicting info
on line, but I think the D is the obs, 4L60E. The CH is sup to be the engine faimly
according to one source, not another, lol. Anyway, cant find what CH is, if engine
family. I realize the trans could have been swapped at one time, but doesn't look like it.
Old Feb 19, 2020 | 09:41 AM
MaroonMonsterLS1's Avatar
Why do you care? it's not like one is inherently stronger if it came behind a tbi 350 vs a 6.5 diesel vs a 5.3 lm7
Bellhousing, input shaft type, and tailhousing...that's all that really matters physically.
You can update anything internally to make it work best for your setup
Old Feb 21, 2020 | 06:20 PM
vorteciroc's Avatar
As Maroon Monster said... what is the difference in reality...
The transmissions did not vary just because a different size/ output engine was in front of it.
It is a 4L60E transmission for all that matters.
On top of that; It also doesn't matter if the transmission is a 60 or 65 variant... They are essentially all the same and need to be modified regardless.
If you really need to know, OCHD with a 2 piece case is: For 2000 Chevy two wheel drive Tahoes, Suburbans, and Silverados with a 5.3L engine.
Old Feb 22, 2020 | 06:09 AM
forcd ind's Avatar
Thanks-I was trying to ID the engine, 4.8 or 5.3 before I bought it-the trans looked like
it had never been sep. from the engine, but I didnt think the engine was a 2000, maybe the trans
was swapped early on. It ended up being a 5.3, I only wanted the engine, but the trans was
left on it. Never been inside a 60E, rebuilt some 80E's, I guess a project later on.
Old Feb 22, 2020 | 09:33 PM
vorteciroc's Avatar
If you guys are ever trying to identify an engine...
The best ways to do so, are from:
-The Vin of the car of truck that the engine was originally installed (the 8th digit of the VIN relates to the engine RPO).
-The RPO sticker of the car or truck that the engine was originally installed (one of the L designated codes will be for the engine).
-The partial VIN that is etched into the cylinder-block of the engine.
-The partial VIN that is etched into the transmission case
Most importantly...
The Broadcast Code of the transmission is NOT a good way to identify an engine!
The Broadcast Code of the transmission does not provide any engine specifics by it self...
For example a partial VIN is needed to know if a 6.0L engine is a LQ4 or LQ9.
The transmission Broadcast Code will not provide the information required to know this.
