Crazy occurrence
Many of the after-market and some of the OEM brackets can be installed in an incorrect position on the transmission...
The bracket for the gear selector cable may be bolted/ mounted to the oil-pan rail in the wrong position.
If this is the case, you may find that the bracket needs to be moved rearward one bolt hole and have the cable re-adjusted back how it was previously.
