1st swap needing help
Old Mar 3, 2020 | 10:40 PM
tchrisiz's Avatar
Default 1st swap needing help
I’m currently doing by first Build and need some advise. Using a 2004 LQ4 from a Escalade and trying to use a 6L80 from a 08 Escalade. Been told the flexplate will have to be changed. Is this a fact or can I use the factory flexplate and the starter and torque converter will work as it should. Thanks in advance.
