Failing Torque Converter?
Parked the car at home checked the fluids, little dirty but in range. Car lost all gears R D 1 2 3.
Turned the car off restarted and it found drive to pull up on ramps.
Changed fluid, can see the pump is working. HP tuners is showing gears holding. Brought it back home and it lost everything again and then came back.
Thoughts?
The car went back to normal after a fluid change for a day and then repeated the no gear at all. Turned it off, restarted and drove it back in the garage.
as for transmission, everything looks good inside, so nothing was spread through the unit.
Accumulator piston cracked a few months later. New piston, clutches & seals after opening it up a second time.
$27 part can have some major impacts to the functionality of the overall unit.
After 16 years and 91K miles of nitrous abuse, it needed a complete change.
