2003 4l80E weird problem
basically i can feather truck in 4th but anything more than 1/8 throttle itll kick back into 3rd
it isnt slipping, no check engine, speed gauge is jumping around after 40 mph until 75 mph
noticed it has a new throttle body put on and wire up with a new pigtail,
B. Read the codes. No light on dash doesn't mean there aren't any codes...it means there is no light on the dash.
C. speedometer jumping all over is a clear issue. Don't keep driving it without finding out why the gauge is bouncing. Is it the dash? Is it the speed sensor? is it the connection to the pcm from the trans?
D. Check live data and see if 4th is being commanded when it falls back to 3rd. If the PCM is commanding 4th but the trans is in 3rd anyway...that's a clear indication of an issue.
Do a little more checking and let us know what you find.
ill post and update on what my tranny guy finds
