2002 vs. 2004 RWD 4L60E interchange? Park Neutral Plug is different.
Old Apr 15, 2020 | 09:21 AM
waid786's Avatar
Default 2002 vs. 2004 RWD 4L60E interchange? Park Neutral Plug is different.
Would a 2002 Tahoe RWD 4L60E interchange with 2004 Express 5.3 4L60E ?
I know there was some changes around 2004/2005 in 4L60E RWD and the Park Neutral Switch was changed from duel to single type.
I think as long as the park neutral plugs are the 2 separate type, then it should be the same ?
Waid
Old Apr 15, 2020 | 10:04 AM
MaroonMonsterLS1's Avatar
Only swappability difference is the switch you have pictured.
The rest is direct interchange.
