Brake Sensor Switch
Old Apr 30, 2020 | 02:32 PM
Loren Barnes's Avatar
Default Brake Sensor Switch
If i run a brake light (12v.) to a relay, that sends the voltage to pin 9 on the ECM when the pedal is pushed, where do I run the Blue/white wire from the L80E trans?
Last edited by Loren Barnes; May 12, 2020 at 01:59 PM. Reason: question unclear, needs better description.
Old May 1, 2020 | 07:52 AM
MaroonMonsterLS1's Avatar
Nikon or Canon? Or maybe FujiFilm?
Brake switch signal goes to pin9 on the 73 pin ecm connector
Not sure what eco x1 is that you're referring to
