wiring in rear mount trans cooler
Old May 5, 2020 | 07:08 AM
BaldEagleWS6's Avatar
Default wiring in rear mount trans cooler
As the title says Im needing some help with wiring in my trans cooler.
Ive got a 98 WS6 and Im finishing up the 4l80e swap car was originally a 6spd. Ive got my trans cooler mounted in the rear of the car under the Ttop storage. Ive got a fan mounted to be a puller. i dont want to run the a toggle switch in the car. Is there a power source in the rear of the car i can tap into that will have my fan kick on when the car is started and shut off the fan once the car is off? would tapping into the antenna work? I don't use the radio since my phone is plugged in.
thanks for any info and help.
Old May 8, 2020 | 08:46 AM
thedetroitkid's Avatar
No- you’ll have to pull power from some terminal under the hood. This is where having you battery mounted in the trunk comes in handy
Old May 8, 2020 | 09:04 AM
mrvedit's Avatar
Moderator
If you did have the battery in the trunk you could wire the battery to a relay to power the fan. The "signal" to turn on the relay could come from the fuel pump.
No, you cannot run the fan on the same circuit as the fuel pump because the wiring to the fuel pump is already marginal and you cannot double the amount of power through it.
A fuel pump typically takes 10 Amps. Your fan probably takes at least 10 Amps.
Tell us how many amps your fan pulls and that might help us guide you in a good direction.
Old May 8, 2020 | 01:07 PM
biketopia's Avatar
Build your own hotwire kit and then double it up to run the pump and fan.
Old May 13, 2020 | 08:36 AM
Jegs states the fan has 5.6amps draw, its one of their cooler/fan combos. PN-555-60389
I wasn't planning on splicing into the fuel pump. I was gonna use the Key switch wire to the power antenna to run the fan. It would stay on until the door is opened or after a certain time it shuts off. Would that be a decent power source to run the fan?
Old May 17, 2020 | 12:51 AM
truckdoug's Avatar
i use that fan & cooler on my malibu. it spikes to ~15A when it kicks on. run a dedicated 10 gauge wire to the power side of your relay and the fan +12v
Old May 17, 2020 | 12:03 PM
mrvedit's Avatar
Moderator
I tend to over-wire things, but IMHO a dedicated 12 Gauge or even 14 should be plenty big.
Here is a useful chart showing wire gauge sizes needed in Cars/Boats depending upon amperage and wire length, while allowing either a 3% or 10% voltage drop.
IMHO a 10% voltage drop to a fan which only runs when the engine is running is fine.
https://www.bluesea.com/resources/1437
