4l60e problems
Old Jun 2, 2020 | 08:05 PM
Shawn c's Avatar
Default 4l60e problems
Need some help please. i have 03 Silverado z71 & about a year ago transmission went out.so bought a new one frm autozone. Well its been a year & i started modifying my truck.anyways i put a cheap Amazon tc in it.well first day took off frm stop lite and b4 it shifted it started clanging and went out.so under warranty got a new transmission about 3 weeks ago and i bought a hays 3200 stall converter becuze i was camming it well i did all that got it tuned a few days ago & today i took off frm a stop.& went threw 1st on to second gear and rpms went up to like 6 grand .now when i take off rpms are going real high have to let off for it to catch .& got a message on dash saying transmission is to hot so checked cooler and its as cool as out side.but tranny is hotter then hell so i pulled line off cooler and its jst dripping out. Now when i get in it it will take off fine in 1st gear but dont last long then its back to high rpms.kinnda like if it had no fluid in it.i jst put alot of time and money in to this damn thing .can anyone tell me whats probably wrong maby the pump went out.o and 2 days b4 this happened on way to work my transmission was screaming only when idle was high but was screaming like a wet serpentine belt but when i got back in truck when i got off it wasn't so dont know if that had anything to do with its demise. I was thinking the tc is bad but its brand new too so im at a loss here if anyone has any ideas i sure would be grateful & thanks
Old Jun 4, 2020 | 06:10 AM
bbond105's Avatar
The rebuilt units that you can pick-up at your chain auto parts stores are not a quality unit, neither are the torque converters that you are using. But it sounds like you may have broken the pump gear when installing the torque converter.
Take one of the transmission cool lines loose from the cooler, have someone start the engine and observe now much fluid comes out. A lot should come out very fast.
Old Jun 4, 2020 | 07:48 AM
Shawn c's Avatar
yea i took cooling line off and it was dripping a tiny bit & i put a hays converter in it i think thease transmission from autozone are junk i pulled pan & it looked like someone had a glitter party plus fluid was burnt bad and stunk.also i could see a drum frm bottom of pan looking up there was a chunk broke out.so im buying a better built transmission today from jegs i really need to flush my converter out now cuz im using it in new transmission. Its a 3200 stall hays tc .& its only 3 weeks old i paid almost 600 bucks for it. Im wondering since thats under warranty should i jst get a new converter as well?
Old Jun 4, 2020 | 09:08 AM
MaroonMonsterLS1's Avatar
Why would you think they should waranty your converter?
If it was your install error, or the error of a bad trans filling it full of metal, what would constitute a warranty?
Old Jun 4, 2020 | 12:56 PM
B52bombardier1's Avatar
Don't forget to replace your transmission cooler, if equipped. Its also likely shot through with those same sparkly metal bits.
Rick
