Blocking the 3-2 shift valve, and yes the 2-3 shift
Old Dec 7, 2020 | 11:22 PM
  #41
Dynamic396's Avatar
Originally Posted by clinebarger
Never thought about leaving the piston out & letting Accumulator oil feed the lube orifice, Thanks.....Even an old dog can learn new tricks!
I know this is an old thread, but I agree 100% with clinebarger. I never thought of this, either. It just goes to show that the day you think you know it all is the day you stop learning.
Old Dec 10, 2020 | 07:39 AM
  #42
2BFAST's Avatar
This thread is so gold.....
Old Dec 18, 2020 | 12:29 PM
  #43
2BFAST's Avatar
So when making stops for the 3-2 Control & Shift valves how and what do ya'll use? I see the OP used copper tubing? What size was that? I have 3/16 - 1/4 - 3/8 stainless tubing still.
Old Dec 18, 2020 | 01:56 PM
  #44
MaroonMonsterLS1's Avatar
Whichever fits.
Just trim to length. Not a big deal
Old Dec 18, 2020 | 10:46 PM
  #45
2BFAST's Avatar
I took 3/8 stainless tubing and made my stops
This is what the 3-2 DOWNSHIFT valve measured too. This is appox BTW. I assume it can vary slightly
And the 3-2 CONTROL valve measured too. Again +/-
Then essentially take the stock 3-2 downshift spring and install it inside the stock AFL spring.
Again, all this considered you make the proper [size=13px]orifice modifications in the separator plate. Which I plan to do. [/size]
Old Dec 18, 2020 | 11:46 PM
  #46
vorteciroc's Avatar
Do not enlarge the AFL balance hole in the separator plate.
Old Dec 19, 2020 | 12:48 AM
  #47
2BFAST's Avatar
I told Dana I was blocking both valves. He said said OK and will mod the 2nd apply hole
Old Dec 19, 2020 | 07:01 PM
  #48
PBA's Avatar
PBA
It was the band release hole, that I enlarged when blocking both valves.
Old Dec 20, 2020 | 08:12 AM
  #49
bbond105's Avatar
Dana what size did you enlarge the band release hole to?
Old Dec 20, 2020 | 12:01 PM
  #50
2BFAST's Avatar
apologies. Correct!
Old Dec 20, 2020 | 01:05 PM
  #51
vorteciroc's Avatar
There really is no standard size 3rd accumulator/ band release orifice...
This orifice size is a factor of the 3rd feed and 3rd exhaust variables.
Old Jun 17, 2023 | 10:46 PM
  #52
vorteciroc's Avatar
For anyone new that is referencing back to this Thread...
I ReMade many of my Hydraulic Diagrams, the 3-4 Clutch with both Valves Blocked.
The Fluid Passages that show as Purple, you should consider them to not exist, as Fluid is blocked to the Passage or at the component.
This is shown below:
Old Feb 14, 2024 | 01:47 PM
  #53
y5e06's Avatar
Originally Posted by MaroonMonsterLS1
Blocking these 2 valves will not affect when the vehicle tries to make a 3-2 downshift. That is still controlled by the computer.
These valves are just used to affect how much time it takes between when the computer commands the shift, and when it actually occurs. (we're talking in the range of tenths or hundreths of seconds difference here. Not multiple seconds)
The two 3-2 valves, in stock form, are just a VERY overcomplicated method of offering multiple exhaust paths of varying distance and flow capability.
Blocking them gives one fixed exhaust path, and you can control the size and speed of exhaust by using the "band release" hole we always talk about on this forum.
Blocking the valves eliminates large circuit leaks in the 3rd gear circuit and cures cross leaking from 2/3 fluid paths.
Also, it gives the builder control of the exhaust path. Once you change clutch count, clutch clearance, band width, servo size, band clearance, shift feed orifice size, pressure, etc...all of the factory programming/timing for the 3-2 shift goes out the window. SO, when the valves are blocked, each builder can use the separator plate to control shift feel for both UP and DOWN shifts.
I block both of these valves all the time. Even on my fiance's grandma-mobile that needed the 60e redone. She notices shift feel and timing better than most guys I know...and she has no complaints. And believe me...because I'm the builder I'd normally get fielded with more complaints than from a usual customer ha!
TLDR version:
Blocking both 3-2 won't hurt anything. It cures leaks. Lets builder use "band release" hole to control the downshift timing to their desired feel
Leave AFL balance hole alone OR drill .078 if it makes you feel better. No harm, no foul.
Revisiting this bit of info for a bit more info.
I've read a few other posts that indicate drilling the Band Release hole to adjust for blocking the valves and timing the shifts. However, I have not seen any suggested new-hole sizes.
what size should one drill the band release hole when blocking these two 3-2 valves?
Does it need to be drilled? Or can it be left stock?
How big is too big?
my particular setup will be the TransGo SK 4L60E shift kit, wide 2-4 band, and corvette servo. I would like to see a mild 3-2 improvement but nothing excessive.
Old Feb 14, 2024 | 03:35 PM
  #54
vorteciroc's Avatar
This was intentionally not answered previously.
Please read the Thread before asking questions.
Old Feb 15, 2024 | 07:15 AM
  #55
reubone's Avatar
I getting that this is a trial and error deal until you have done enough of them to develop a feel for it. A while back I bounced around looking at different recommended hole sizes for several different builds. It always seemed that the band release hole was around 80% of the 3rd feed. Not sure what that has to do with anything but its what I noticed. Maybe that would be a good place to start. How much money could somebody make with a rent by the hour transmission dyno lol.
Old Feb 15, 2024 | 07:25 AM
  #56
I own a transmission dyno
You can't rent it for enough to be worth my time
And if I did charge that...nobody would be renting it
Old Feb 15, 2024 | 09:45 AM
  #57
reubone's Avatar
What would it cost?
Old Feb 15, 2024 | 02:01 PM
  #58
vorteciroc's Avatar
Originally Posted by reubone
What would it cost?
You can purchase either of mine...
One is a twin Electric-Motor 800 Hp Unit.
The other is a Blown Hemi Unit.
Most guys run a wimpy V6 Engine, which works fine and protects the operator from the Transmission or engine coming apart.
I got bored of that...
Old Mar 28, 2024 | 10:14 PM
  #59
AndersonFam-Trans's Avatar
For those of you who have a THM700-R4...
Interestingly, the #14 orifice did not exist yet:
Vorteciroc - So it's ok to block the 3-2 control valve inward on the TH700R4 transmissions? Also ok to block the 4th accumulator hole and leave out the guts of 4th accumulator? Thank you for all info as I was curious of any extra/ un-needed 2-3 / 3-2 exhaust paths as on the 4L60.
Old Jan 3, 2025 | 07:40 PM
  #60
V8fan's Avatar
Looks like to prevent 2-3 flare it require blocking #2 checkball or use sonnax 2-3 valve to slow down 2-4band release
Why they simply not divided paths of 12 and 13 orifices in parallel to control separately 3-4 and 2-4 band oil flow ....
