4l60e issues
Old Jun 24, 2020 | 09:36 AM
ss27gogeta's Avatar
Default 4l60e issues
Car is a 95 firebird transam body has 175k on it the engine has been replaced before I'm not sure about the transmission though. car is mostly stock has 3:42 gears and a cold air intake that's it. this is my issue car won't shift at wot but if I let off it shifts. If I'm driving around normal it seems to shift fine. Also if I'm crusing and its in lock up and i punch it seems not to drop any gears and feels like a dog. But if I slow down it seems to shift down just fine. Is the transmission getting worn out or do I have some sensor issues going on. Thanks
Old Jun 24, 2020 | 05:15 PM
vorteciroc's Avatar
Make sure the ATF level is FULL.
Take line pressure readings for all gear ranges at idle and above idle (brakes applied when in gear).
