Starter teeth grinding!?
Old Jul 25, 2020 | 06:44 AM
SHINER's Avatar
Default Starter teeth grinding!?
70 Chevelle
New 6.0 build, LS7 crank, 4.030, Heads, Cam, LSA blower, 4L80- everything is new.
New Starter is ACDelco 3371131
New flywheel is ATP Z-270 14” 168 tooth
using ARP bolts
im not using shims but the bendix is engaging and turnning the motor over but it is making a terrible intermittent sound. I recorded it and you can see shavings, no teeth are broken. What should I do?
is it uncommon to need shims or do i need to put a spacer in?
