4L80e Converter questions
I've lurked on this forum for years but just never needed to ask anything specific until now. So I have an 84 Corvette that I swapped in an LS1 and a 4L60e a few years ago. Last winter I changed the cam to a 220/224 575 575 112 lsa and I put on 243 heads and headers. I also put in a Circle D 3000 - 3200 stall converter. The car has a Dana 44 with 3.73 gears. And to top it off I put on a Holley Terminator X.
So the car is a street car that will probably never see an actual drag strip other than the local airport flashlight drags once or twice a year. I drive the car to work once a week, all highway so anything I do to this thing needs to be reliable.
This winter I want to swap in a 4L80e and gap the rings for nitrous. I figured since I have Holley efi I might as well use it's progressive nitrous control. So I'm wanting to do a 150 dry progressive shot. I know the 4L60 won't hold up. So I picked up a freshly built 4L80e that I stumbled onto at a U-pull n pay in Pittsburgh. I'm going to dual feed the pump and do a shift kit. So then the last piece of the puzzle is a converter.
I emailed Circle D and Jakes Performance. Circle D is recommending a 3500-3800 stall $1000 converter. Jakes is saying a 3200 billet, again $1000 converter. Does this seem right? Basically this is a 400 rwhp car with a 150 shot of progressive nitrous. Is there a reason a budget 3200 stall Summit racing or even the lower cost Circle D converter won't work? Also Circle D recommending a stall that high seems odd to me. The car rev's lower than that at highway speeds. Won't that high of a stall overheat the transmission on the highway?
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
I guess I'm glad I just paid off my credit card.
