4L60E TCC strangeness (PIC attached)
1999 TransAm H/C/I A4 with 3.73's and 3400 stall.
My question: While normal driving and watching the PCM with my Tech II, I see the PCM command the transmission TCC to LOCK, but sometimes (most of the time) it does not lock for a long time until I hit around 40% throttle position, which it then clearly and solidly locks and stays locked until the unlock command. What would cause this?
It's not locking at all, the converter is a high stall and remains super loose with hundreds of RPMS of slip both positive and negative while above is happening and driving normally.
Pasting a screenshot of my HPTuners settings in case it's something there but I don't think it is because one of my tests was to copy all the transmission settings from another similar car which is working fine and my car still did the above.
No slips at all when locked even under heavy load otherwise.
Someone please tell me it's just a solonoid I can change?
The larger problem I am having is that occasionally it will go into LIMP mode where it shifts hard and TCC stops locking, and then apparently overheats the transmission and pukes out the vent tube, I have no clues on this one yet so chasing this initial symptom. If someone who knows these transmissions can actually link those two events with a good probable cause I'd be super appreciative, as this has left me stranded at 1am about 100 miles from home recently when I boiled all the fluid out the vent tube on a trip. $350 tow.
Thanks guys.
Trying to attach the pic a different way, zipping it so it doesn't render inline.
EDIT: trans and converter are about a year old, I think I noticed the TCC delayed lockup problem months ago though. Just wasn't sure until I scanned it, and didn't need to scan it until recently when I had the boil over leave me stranded LOL.. and no codes.
I actually liked that behavior because it allowed me to "save" the converter clutch from powering through an uphill lockup which I felt saved clutch wear. I'd peak the hill and next application of throttle it'd lock under light load.
I am going to drop the pan and test and maybe even swap out the two TCC solonoids I think, I'll try to check harness and other junk while I'm in there, will be swapping to a pan with drain plug and new filter.. Builder was a bargain builder who cranks out a ton of 4L60Es. The fact there's a high stall and custom tuning makes him not want to really work with me on it (warantee's out so I understand. Trans builders just want to nuke from orbit and rebuild... I get it. I just want to see if I can fix it without a rebuild).
I don't even care that the TCC is behaving this way, but the car left me stranded as I described and I need to trust it again. This is the only odd symptom the transmission is having so hoping if I fix this it'll fix whatever did the limp mode.
Also, trans and TC are a year old but there's a ton of miles, maybe 40-50k. This is my DD I use for work and need to get it reliable again so I can keep driving her :-)
I am going to drop the pan and test and maybe even swap out the two TCC solonoids I think, I'll try to check harness and other junk while I'm in there, will be swapping to a pan with drain and new filter.. Builder was a bargain builder who cranks out a ton of 4L60Es. The fact there's a high stall and custom tuning makes him not want to really work with me on it (warantee's out so I understand. Trans builders just want to nuke from orbit and rebuild... I get it. I just want to see if I can fix it without a rebuild).
This is what I used after several forum experts guided me towards it. I dont believe its your problem 100% BUT I would do it regardless.
There are a few decent YouTube videos of the install.
I "think" when I am on a slower road, the car gets in this "commanded lock but unlocked mode" (and previously I am unaware because without scanning how would you know?) and then after a while of this it goes into limp mode. I was able to replicate it one time while watching it to see how long it would stay in "lock commanded but unlocked" mode and after maybe 3 or 4 miles it went into limp mode where it shifted hard and no TCC at all, and the temp started rising. I stopped and let it cool down. Haven't let it go into LIMP mode since.
It only boiled over that one time because it was 1am and it was a dangerous highway and I did not want to sit on the berm, I drove it in LIMP mode to next offramp and it puked its guts out. I thot it was dead, but once towed home and I replaced fluid and started scanning/testing, it seems perfect except for this TCC problem which I suspect is the root of all its problems.
I was assuming the trans was going into LIMP mode because of the computer commanding TCC lock but the TCC didn't lock for a long time.
Today I tuned it so the TCC command would only occur above 65 MPH, thinking I can babysit it on the highway and this would allow me to cruise around town and buy me some time and use the car.
Apparently I was WRONG. I never reached 65MPH and it went into LIMP mode anyway within 10 miles of driving. AND it finally threw a code while it was in LIMP mode. Finally got a code!!
P1870
So Tyler I am going to take your advice and start with that fixer valve you pointed me to, and while I'm in there I'll ohm test all the solenoids and eyeball the harness etc. We'll see if that fixes her.
I understand that the P1870 is a strong indicator for that valve but not sure how it could trigger when I never commanded the TCC to lock (I don't think). So fair chance I have another problem... I need to google and see what else "could" cause that P1870 just to prepare for possible next step, but I am going to put that valve in anyway. Heck, it's only $20 and from the videos I think I can do it myself.
Any other input from anyone would be greatly appreciated.. I suspect I'm not getting a lot of pro replies because they're all off the clock for the weekend LOL.
P1870
Thanks guys.
Please post a hyperlink to the photo for me if you can.
The slip RPM and percentages are most of the time a metric/ parameter of no value.
The later model 4L60E units that had both a input speed and output speed sensor did actually give some data of value.
The use of an aftermarket "High Stall Speed" torque converter will only make this data more worthless.
The Diagnostic Trouble Code that you have had set, is a generic "component slipping" code.
The PCM has approximated this information as it has no actual way to compare data from sensors to calculate/ perform math from data to detect "slipping".
The later units with ISS go about this in a much better way.
Also it is common to require a re-tune/ have DTCs ignored regarding "slipping"... The higher stall speed of the torque converter can not be differentiated from an actual slipping component (especially in the earlier units).
It is absolutely advisable to test and make sure that the lock-up clutch can apply and hold lock-up.
This is where I would start... and then go about having a tune done for the transmission.
If the torque converter is not locking-up, the transmission will overheat.
Hopefully you have added an addition ATF cooler along with the "High Stall Speed" torque converter.
The transmission overheating can also prevent the lock-up command...
It is time to start checking that the TCC lock-up function operates electrically (bench test if you will) and hydraulically.
If you do not wish to dive in yourself... then it is time to visit a transmission shop.
