Th400 or powerglide?
Old Oct 6, 2020 | 08:43 PM
DirtDE19032's Avatar
Default Th400 or powerglide?
I want to start buying parts to have a trans built for me but I’m not sure which direction to go. I’m trying to be as budget minded as possible. I have a gen 4 6.0 with 88mm vs racing turbo. 04 mustang that is for 1/8th mike racing only. My goal for power is anything above 900hp. Which trans will be best for a setup like this? Which parts should I start buying to piece together a trans that will hold up to my goals? I haven’t decided where I’ll be taking it to get built and I don’t have 4 or 5 grand to drop on it when I take it to the shop. Hence why I want to accumulate the must have parts right now.
Old Oct 7, 2020 | 07:43 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
Since you are 1/8 racing only I would go the Powerglide route, lighter, less HP to operate, and less moving parts to have a possible issue with. And building one to hold your power level definitely won't break the bank. A key factor here will be converter choice as well. Make sure you get a quality custom spec'd converter for your setup.
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
