2 step with a 4k stall
Old Oct 24, 2020 | 07:14 PM
K!ssmySS's Avatar
Default 2 step with a 4k stall
Did some reading and I can't find a straight answer on how to set up my 2 step on a 4k stall, trans is a 4l80e with yank ss4k N/A car. I have the LNC2000 box got it for the timing retard feature for nitrous and want to play around with the 2 step just dont have any ideas were to set rpm I've read go 4-500 under you stall speed and some saying go the the full stall speed or flash it.
Old Oct 24, 2020 | 09:31 PM
This might get more action in the nitrous section.
Old Oct 24, 2020 | 11:15 PM
CattleAc's Avatar
Try the auto trans section.
Old Oct 25, 2020 | 12:25 AM
K!ssmySS's Avatar
how to move to different sections kind of new to this still
Old Oct 25, 2020 | 06:17 AM
nj02z's Avatar
You will not hold the car back that high(3500/3600) unless you have a trans brake. Start at 2000.
Old Oct 26, 2020 | 11:06 PM
K!ssmySS's Avatar
[QUOTE=nj02z;20299105]You will not hold the car back that high(3500/3600) unless you have a trans brake. Start at 2000.[/QUOTE i don't have a trans break so start at 2k but don't go higher then the stall?
Old Oct 27, 2020 | 02:39 PM
FTICONVERTERS's Avatar
LS1Tech Sponsor
You're going to need to play with it and find what works best. Go as low as 12-1500 and up to stall speed. Different cars work differently. experiment and find where you get the fastest 60ft. Just make sure your staging is consistent while testing to get accurate data.
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
