Msd 2 step with trans brake wiring
Old Dec 29, 2020 | 04:29 PM
graderbird2004's Avatar
Default Msd 2 step with trans brake wiring
I have been looking for some time now and I am having a hard time coming up with a good wiring setup. I have a 2000 camaro turbo 5.3 build. I am running a powerglide with trans brake. I also have a hurst pistol shifter with button. I bought the msd 2 step and wanting to run that to the hurst button and trans brake at same time. I'm not wanting to run through a relay, but rather just a simple setup. Does anyone have a wiring diagram of this setup?I am also thinking about wiring the other wire of 2 step to a momentary switch by itself so I could run independent of trans brake. Any help would be appreciated!
Old Dec 29, 2020 | 08:37 PM
vorteciroc's Avatar
What is your definition of a "good wiring set-up"?
My definition would include the proper use of relays...
Are you trying to just get it done "quick and dirty"?
Or do you want it done correctly?
Which MSD control-module are you using... I will try and make a diagram in paint if you tell me what components you are using (trans-brake solenoid, Etc...)
