Inputshaft leaking?
Old Jan 1, 2021 | 05:12 AM
dan67's Avatar
Default Inputshaft leaking?
I've been doing a 2001 4l60e rebuild. I got the input drum assembled and was checking for leaks. I could here a leak air checking and found it leaking between the shaft and drum on the inside of the drum. I already pressed the Sonnax Reinforcement sleeve on. Can I press the shaft out put red loctite on the shaft, then press it back in or am I screwed?
Old Jan 1, 2021 | 08:00 AM
bbond105's Avatar
Yes, you can still press the shaft out and seal it. I have done this a few time with no issues, It is best to check for leakage here on tear down or before installing sleeve, or just go a head and press the input shaft out and reseal it. Most shafts leak here anyway.
Old Jan 1, 2021 | 07:56 PM
dan67's Avatar
Thanks, I had to get another input drum. The old shaft was damaged. I should of put the parts in the drum and tested it. Lesson learned.
Old Jan 2, 2021 | 07:46 AM
bbond105's Avatar
If the shaft is damaged and not the drum, then just replace the shaft. Most likely you will have to reseal the shaft in the replacement drum.
