4L80e late model soft 1st gear
Old Jan 17, 2021 | 08:48 PM
Thumpn's Avatar
Default 4L80e late model soft 1st gear
For some reason I can not get the trans to 60ft! It is quick off the button and i am killing the tree with .00's but after the button release and about 1 ft of movement it acts like i very mild throttle stop, so I am thinking i have a setting in the trans tune that is not allowing to put down the power? I cant get better than a 1.91 60ft leaving any where from 2900-4200 rpm. with anywhere 3lbs to 12lbs of boost. but once it shifts into 2nd gear it goes like a raped ape! I have taken many starting line photos and videos , and i can tell you I am not spinning my tires
please ask if there is any other info needed
411 ecm
6.0L 9:1 comp
btr stage 3 turbo cam
823 rec port Ls3 heads
vsr 88mm t6 turbo
btr intake 102mm tb
160 lb ID injectors
twin areomotive 340lph in tank pumps
aeromotive boost ref regulator
boost leash boost controller
innovative wb
Built 4L80e late model
billet hubs and shafts
D3 T brake
triple billet triple lock up 10" race converter 4000 stall
File Type: hpt
Old Jan 18, 2021 | 07:41 AM
MaroonMonsterLS1's Avatar
post a log when it happens also
Old Jan 18, 2021 | 08:01 AM
Thumpn's Avatar
it happens all the time. attached is my last log
File Type: hpl
