4L60e front pump failure
Old Feb 14, 2021 | 09:44 AM
td1168's Avatar
Default 4L60e front pump failure
Hey guys, I wanted to share a few pictures from a front pump failure I had. I bought this transmission new and drove it for about 800 miles before the front pump failed. The place I bought the transmission from never gave me a good reason why the pump failed and I’m not sure you can tell much from the pics. Just looking for some expert advice on what may have caused this. Thanks
Old Feb 20, 2021 | 12:22 PM
td1168's Avatar
Nobody??
Old Feb 20, 2021 | 12:30 PM
vorteciroc's Avatar
I did not want to be the one who said anything, but...
Excluding the cylindrical filter-element; the parts in that pump do NOT look new.
This is not 100% certain, but It looks as if someone threw a used/ worn pump into the transmission.
Old Feb 20, 2021 | 12:34 PM
mrvedit's Avatar
Moderator
When you say "new" do you mean really new from GM? Or a rebuild? I suspect the later.
The failure point is not obvious to me, but the wear on the rotor and surfaces on the pump halves is excessive. Many rebuilders will re-use marginal rotors and pump halves. Very good rebuilders will re-machine the pump halves and use a new rotor.
Actually, the failure point could be below the pump slide where the ring and o-ring should be in good condition; else pressure will leak out of there.
Old Feb 20, 2021 | 02:43 PM
vorteciroc's Avatar
I can not quite see for sure in the photos, but it looks like the torque-converter at one point made witness marks on the rotor.
Old Feb 20, 2021 | 04:08 PM
td1168's Avatar
It’s not new from GM. It was bought new from a reputable performance transmission shop. They fixed the transmission under the one year warranty but I don’t have a lot of faith in the transmission. They blamed the stock flexplate or converter ballooning but I’m not sure that’s the case. The flexplate wasn’t bent or cracked and I’m running a Yank SS3600 converter.
Old Feb 20, 2021 | 04:19 PM
td1168's Avatar
The company that built the transmission said that was a possible cause of the failure but I had an 1/8” between the converter and flexplate when I put the transmission in and Yank said the SS3600 has an anti-ballooning plate. I didn’t do anything different when I put the transmission back in so I’ll hope it doesn’t happen again. I originally thought when I saw the pics that the pump may have been starved of trans fluid and caused the damage. The transmission never slipped before this happened.
Old Feb 20, 2021 | 05:58 PM
vorteciroc's Avatar
I can not say for sure what happened, but...
In the mechanical world (or any industry involving assembly within close tolerances) there is the possibility of "Stacked tolerances" or "Tolerance Stack-Up".
Lets say 4 equally sized parts need to fit together inside of a 1.5" tall space with a 0.5" gap of clearance left over.
In a perfect world... each part would be 0.25" tall.
However in reality these parts may actually be 0.23" with a 0.01" to 0.03" variance in either direction.
The part could be anywhere from 0.20" to 0.26".
The 4 parts will fit in the 1 inch tall space most of the time...
However, for example if we have 2 parts that are 0.25" tall and 2 parts that are 0.26" tall.
This would mean that we have a 1.02" tall assembly of the 4 parts.
This does not give us 0.5" clearance in a 1.5" tall space... we have 0.48" of clearance.
This makes for an unacceptable amount of clearance.
Yes the 1.02" tall parts will fit in the 1.5" space... what I did not tell you is the purpose of the 0.5" required clearance.
The 0.5" clearance is for the parts to grow when temperatures increase.
We need 0.5" of clearance for our 4 parts to grow and not crush each other.
Lets just say that the 0.48" clearance is not enough and our 4 parts do crush each other and fail.
This can actually happen between the pump rotor, pump halves, torque-converter ETC...
Normally the stock rotor will break apart or crack in 2 pieces...
You do not have a broken rotor... but could the excessive wear be from not blue-printing the pump clearances, and not setting the torque-converter depth properly?
Yes possibly... but the plastic rotor guide is not new (discolored from being in old oil), the stator-support tube is rusty, and there is a high amount of wear and tear in the pump...
Old Feb 20, 2021 | 06:31 PM
vorteciroc's Avatar
Pretty much whenever the pump is not able to suck ATF up from the pan; it is because the wrong filter is being used, or an oil-pan/ filter miss-match...
or the seal that goes into the pump for the filter is: wrong, or not replaced with the filter and is old/ leaking, installed incorrectly (crooked or double-stacked), ETC...
Old Feb 20, 2021 | 10:23 PM
Tranzman's Avatar
I've seen that type of damage on units with a deep pan and a shallow pan filter was in stalled by mistake.
Old Feb 22, 2021 | 07:11 AM
MaroonMonsterLS1's Avatar
Sorry but...what do you say the failure is?
I don't see a broken rotor or slide or vanes
What made you stop and take it apart?
It is clearly scarred but I'd be looking at that bushing and I'd be worried about that.
Anywho...none of that looks good by any means...but why did it stop you from driving it? Did line pressure fade, did it start to puke fluid out the front, etc
Old Feb 22, 2021 | 12:24 PM
Papermachtech's Avatar
I'll step into this and Play the chicken or the egg game.
With the caveat,it is impossible to ascertain what happened with 100% accuracy.
But one can make some assumptions.
The worst damage is on the back side of the pump. Suggesting a axial thrust issue.
One can also identify marks on the drive gear of the pump that suggest the same axial thrust issue.
Some marking on the internal diameter of the pump drive gear indicating more wear that I would expect for 800 miles.
This suggests the vane pump may have not been replaced but isn't prof.
Not every rebuilder replaces the pump parts if they pass inspection.
A picture of the converter hub might also be helpful. As you know it was new.
Inspect the lower recess of the pump drive notch. It it has marking from the pump drive lugs I would assume its a thrust issue.
What was the flex plate to converter clearance?
Rick
Old Feb 22, 2021 | 10:35 PM
mrvedit's Avatar
Moderator
Rick: That's great insight and a very plausible explanation, especially for a failure after just 800 miles.
Considering your obvious knowledge and insight, why only 49 posts in 14 years? Loose the password or something?
Like MaroonMonster, I'm also curious what the symptoms of the failure were.
Old Feb 23, 2021 | 12:41 AM
bbond105's Avatar
I don't think that pump stopped pumping fluid. I would also like to know why the trans was pulled.
Old Feb 23, 2021 | 09:00 PM
td1168's Avatar
I stopped driving it because the shifts went soft and delayed. I didn’t have a line pressure gauge but the line pressure obviously dropped. When I pulled the converter out of the pump one of the metal vanes was laying right behind the seal. Also, I know it’s hard to see but some of the vanes have galling on them. Below are pictures of the converter hub.
Old Feb 23, 2021 | 09:07 PM
td1168's Avatar
Rick
I had a little over an 1/8” gap between the flexplate and converter. I am running nitrous at a 600rwhp power level. I think I previously mentioned the transmission builder blamed converter ballooning but Yank said the SS3600 converter should be fine at my power level.
Old Feb 23, 2021 | 09:17 PM
vorteciroc's Avatar
Mmmm... Converter spacing.
Old Feb 23, 2021 | 10:54 PM
I recently retired. and have more time. I worked in Reliability for a living. I have been involved in many RCA's (root cause analysis) and stuff like that.
Every mechanic should have to rebuild transmissions and suffer the consequences when something goes wrong.
It will make you a better mechanic than 90% of them.
Last edited by mrvedit; Feb 24, 2021 at 10:45 AM. Reason: Moved post from another thread
Old Feb 23, 2021 | 11:03 PM
Converter ballooning is an issue few and far between.
A stock 4l60e converter can and does regularly see line or near line pressure when under lockup.
Basically any decent performance converter now a days is incredibly unlikely to balloon.
The front pump bushing looks freaking smoked. What's the story there?
The pump does look very scarred but no real evidence of chicken vs egg. Looks like spacing issue somewhere in the pump stackup.
Old Feb 24, 2021 | 03:25 PM
td1168's Avatar
When I pulled the converter out of the transmission it was a bitch to pull out because of the pump bushing being tight. What I originally thought was part of one of the drive keys on the pump rotor was actually one of the vanes from the pump. It was just laying back in the pump bore right behind the front seal. A couple of the vanes were tore up even though it’s hard to see in the pic. I know I had an 1/8” gap between the flexplate and converter when I initially installed the transmission. If it was a spacing issue I should be good now. Somehow between getting the converter hub replaced and the front pump rebuilt I ended up with 7/32” between the flexplate and converter. I put a .085” washer between the flexplate and converter mounting pads when I reinstalled the transmission to get me at approximately an 1/8” before pulling the converter up to the flexplate. Hopefully it’s all good now. Also, you mentioned pump stack up. Do you mean that when they reassembled the pump there wasn’t enough clearance between the sides of the vanes and the pump housing halves?
