Flex plate bolts
The manual says 3 passes 15ft/lbs, 37ft/lbs, and 74ft/lbs.
No mention of replacing or torque to angle.
That said ARP flywheel bolts are always a good choice for race applications.
What do you even use blue Loctite for?
I've always figured that if I want something to stay put, I might as well use the toughest stuff available.
Otherwise using the "Red" type, may cause stripping of threads or the Head of the fastener upon removal.
Often a Thread Locking Compound will not be needed with steel fasteners in aluminum (unless the Torque-Spec is very low or the Fastener is very small).
Anti-seize Compound if often a better choice for aluminum.
