4L60E Build Advice
Trans is going in a 02 Firebird with an LS1 engine making around 450 rwhp. It will have a 4000 stall converter and 410 rear gears. I plan to rev it to 7200-7400 rpm.
This is how I plan to set the transmission up.
Clutch Clearances
Reverse Input Drum .040" To .070". Forward Clutch .030" minimum and .063" maximum 3-4 Clutches .025" minimum and .040" maximum Band clearance of .075" minimum and .125" maximum
A "waved" steel to replace the Belville steel in the Reverse Input Drum.
For the Input Drum I have a homemade copy of the Sonnax Smart-Tech drum with 8 BorgWarner High Energy 3-4 frictions and Kolene steels. TransGo 7-CS clutch spring kit
In the Pump I plan to use a 7 vain rotor.
I will be using Sonnax 2nd and 4th apply servo
Separator Plate Feed Holes
Reverse .104” Band release .104" Check ball Hole that is next to this hole just left of Band Release Hole should be blocked 1-2 feed hole to .099" (with Sonnax 2nd apply servo) 2-3 shift feed hole to .155" 3-4 feed hole to .140" to .155" (with the Sonnax 4th apply servo) 3-2 hole to .120" AFL balance leave it stock Must block the 3-2 control valve to use the larger 2-3 feed hole and band release hole.
I am using the Sonnax HD 2-3 Shift Valve so I will leave out the overrun clutch check ball in the vale body.
In the case I will block off the 4th accumulator feed and leave out the accumulator piston. Also leave the #6 check-ball on the case-side of the separator plate.
Valve body I will be blocking the 3-2 Down Shift (#389) and 3-2 control (#391) valve inboard. Installing a Sonnax HD 2-3 Shift Valve 2 Sonnax Forward & Reverse Abuse Valve kits Sonnax 2-3 O-ring end-plugs
Along with parts from a TransGo HD-2-C kit.
After installing a Sonnax .490 boost valve I will check line pressure and if short of 245 psi I will adjust higher with an EPC Solenoid adjustment.
Thank you for any guidance that you can share with me.
Brian
Do you mean you added the reinforcement sleeve kit and special piston? Did you add their special apply plates and a cap on top and drill & tap15 holes for hold-down screws, or something else like a 4L79? Thanks.
The 6T45E in my wife's car went out yesterday so I'll be busy with that this week. After I recover from that I'll look into ordering another Sonnax Smart Shell to keep in stock.
1/16 NPT is also a good option.
NPT preferred but I've used the setscrew 100's of times without issue
If you are not careful with the 5/16" Plug, they can leak...
I have seen many that have leaked without enough Red Thread-Locking Compound.
It seems that the solidified Thread-Locking Compound does most of the sealing at times.
the 5/16" Plug is fine.
I just wanted to make it clear, that the Plug may leak without enough Thread-Locking Compound.
(Must be dry/ hardened before Air-Checking).
Monster, if I can't find the 1/16NPT and go 5/16NC, did you need to use a bottoming tap?
Thanks everybody.
Brass versions are definitely available for much less money than you found.
Just get a Steel Plug and be done with it.
