Flexplate
Thanks, Mike
Thanks, Mike
Then use the same style Flex-Plate from the 5.7L engine.
That would be all that is needed.
Below is an image of both the Thick and Regular style Flange at the rear of the Crankshaft:
In regard to the Torque-Converter to Flex-Plate spacing... every installation is different.
You will want approximately 1/16" to 3/16" spacing; with 1/8" being ideal.
The easiest way to measure the spacing is with Drill-Bits in those 3 sizes.
Use washers between the Flex-Plate and Torque-Converter mounting-pads to establish the correct spacing.
If the Flange at the rear of the Crankshaft (the part that the Flex-Plate bolts to) is thicker on the 6.0L engine; compared to the 5.7L engine...
You are going to find a Torque-Converter company that offers custom Torque-Converters.
The 4L60E Transmission was never intended to be used with the Engines that have the thicker Flange style Crankshaft.
I would try FTI Performance (they are a Sponsor here) and see if they can build a Torque-Converter for this application.
FTI Performance: 866-726-8358 ask for Dalton, and tell him you are a member here.
Website: Link
Good Luck and have fun!
