4l60e VS 6l80e Roll Racing
Old May 21, 2021 | 03:59 AM
MAjdi ALharthi's Avatar
Default 4l60e VS 6l80e Roll Racing
Hello everyone,
a general discussion about 4 vs 6 gear auto ,lot of my friends & other racers saying that the 6l80e is way better than 4l60e when doing street racing (rolling) is that true ! & what is the advantage of having 6l80e ?
Old May 21, 2021 | 11:07 PM
vorteciroc's Avatar
There are a MASSIVE amount of additional factors other than the Model of Transmission...
If the vehicle with the 6-Speed 6L80E is a Garbage Truck that weighs 15,000 Lbs, and has a small diesel engine producing 200 HP...
and the vehicle with the 4L60E is a Camaro that weights 3,000 Lbs, and has an engine producing 1,000 HP...
Who do you think would win a 1/4 Mile Drag-Race???
So if you would like to have the Forum Members here answer a realistic question that contains all the necessary and pertinent information...
We can do that.
If not, then do not hold your breathe waiting for a realistic answer.
Old May 23, 2021 | 06:09 AM
I understand Vorteciroc
let’s say two gto both LS3 engine but with different transmissions 4l60e and 6l80e what is the benefits of having six gears? For Roll racing?
And Is it true 4l60e will kill Hp at high speed?
We can do that.
Old May 23, 2021 | 12:04 PM
vorteciroc's Avatar
As long as both vehicles have the proper spec. Torque-Converter...
Then neither is true.
Old May 24, 2021 | 08:16 AM
mk3cn4's Avatar
In my opinion and personal experience, with stock torque converters there are "gaps" between the gears that are sub-optimal power-wise, and between shifts your RPMs can leave the highest power band. Simply put, more gears reduces that area and on a roll at any given speed your chances of landing in the strongest RPM area are greater with more gears to select from. I've never heard 4L60e will kill HP at high speed...? You mean a speed high enough that 4th gear has you exiting the high point of your power band? I bet that'd be over 200mph.
With a properly designed high stall torque converter this all turns into complicated math and much of this can be designed into the torque converter and it turns very grey, search for STR and Shift Extensions and torque multiplication and you'll get some ideas. But since your question was about transmissions I think my statement above sums it up reasonably well.
