4l80e early vs late "hub height" difference
but transstar offers everything in two hub heights for early vs late
https://www.transtar1.com/products/t...rque-Converter
I build only a few pre-'97 unit a year so I dont run into this much but i'd sure like to know!
Mistakes happen in TC manufacturing, just like anything else.
The more and more rebuilding that I have done with Engines, Transmissions, Transfer-Cases, Differentials, Carburetors, Turbochargers, Alternators, Power-Steering Pumps, Etc...
The less and less I trust "out of the box" measurements... and the need to double check all critical measurements and clearances.
Pressure Regulator Springs came up recently... I has two of them bite me in the *** years ago...
Now every single Spring gets checked on one of my Pistol Spring Testers.
I refuse to get fooled another time.
Another type of Spring that requires meticulous testing would be Engine Valve-Springs...
The Spring Pressures and Heights vary a good amount; so I always have to painstakingly Shim them into Spec.
I guess my post was kind of ambiguous as what I'm actually asking. I'm confused on application of this hub height measurement.
What are they actually measuring to get this height? Do the converters not interchange between the early/late pump types? What are the year models that do which?
