4l60e rebuild
- Gasket and seal kit
- Filter
- Raybestos GPZ 2-5/8” wide 2-4 band
- Raybestos Stage 1 friction in OR, FWD, L/R & Reverse clutches
- 4L75 input drum with 8 Oversized Raybestos GPZ 3-4 frictions or upgrade to the 4L79 drum
- Sonnax Oversized pressure regulator valve
- B/W 29 element Input sprag
- B/W Low roller element
- New EPC solenoid
- New Shift solenoids
- Aluminum Accumulators
- TransGo HD-2 shift kit. (allows holding 1st to any RPM) comes with .500 boost valve
- TransGo No yo-yo pump ring kit
- Corvette or Sonnax 1-2 super servo
- Superior 4th servo (if using the corvette servo) Sonnax 4th super servo
- Sonnax Smart shell
- Sonnax HD 3-2 shift valve (applies Overrun frictions in 3rd,2nd & 1st.
- Sonnax Input drum reinforcement kit
I wouldn't purchase an over-sized Pressure-Regulator valve (or any valve) before vacuum-testing.
I do not like the Superior Transmission 4th Servo design with the Lip-Seal on the Piston... the Sonnax version is very nice though.
I also would stay with the OEM Borg-Warner Frictions instead of the Stage-1 frictions (I do actually really like these in other applications).
The GPZ Frictions are great for the 3-4 Clutch, just like the OEM High-Energy Frictions.
To each their own.
I personally quit letting folks hand me parts about 20 years ago.. Too much hassle and no gain for me.
Especially when you tell the customer they brought the wrong part and they drag you down the internet path of pain to try and prove you wrong.
When I did take their parts is was "NO WARRANTY OF ANY SORT.. " Too many counterfeit parts out there..
I have very good luck with Superior 4th servo.
I almost exclusivly use GPZ-105's and .095 Lindered steels for the 3-4. I have used the GPZ-100 and .077 steels, both give a good clearance for a 7 friction stack. B/W hi energy is my go to for stock, but I still use the 4L65E frictions for a 7 friction stack.
