2001 C5 Auto Transmission slipping
Old Jul 15, 2021 | 07:28 AM
bpulfrey's Avatar
Angry 2001 C5 Auto Transmission slipping
Last time I drove my 01 vette 3rd and 4th gear seem to be slipping. 1 and 2 gear seemed to be fine. Any ideas?
Old Jul 15, 2021 | 10:52 AM
bbond105's Avatar
Have you checked the fluid level, is the fluid burnt, how many miles are on the trans, is the trans stock, how much hp are you putting through it? With the very limited info you have given, my idea is it's time for a rebuild.
Old Jul 16, 2021 | 08:38 AM
bpulfrey's Avatar
Appreciate the reply,
I haven't checked levels, 86k stock transmission. Standard HP.
Old Jul 16, 2021 | 10:25 AM
Zmg00camaross's Avatar
Check fluid. Good time to get it serviced anyways, slips again it’s time for a rebuild.
Old Jul 16, 2021 | 04:03 PM
antoine's Avatar
3-4 clutch pack gone time for rebuild
Old Jul 16, 2021 | 07:37 PM
vorteciroc's Avatar
While a burnt/ worn 3-4 Clutch-Pack is common... it is not the only possibility.
Fluid condition and cleanliness (level of debris) is going to be a big factor.
-The Third-Accumulator Check-Ball Capsule may no longer be sealing.
-The Input-Drum Check-Ball Capsule for the 3-4 Clutch Apply-Piston may not be sealing.
-Either of the Shift-Valves/ Valve-Train may be getting stuck/ obstructed/ damaged by debris.
-There may be leaking/ cross-leaking Circuits in the Bore for the Servo-Assemblies.
-There may be restricted or blocked passages in the Separator-Plate.
-And several other possibilities.
Most of what I posted above will result in a 3-4 Clutch failure...
However, replacing the 3-4 Clutch Pack without finding the source/ cause of the 3-4 Clutch failure, will just cause a repeat failure.
Good luck!
