PNP 1999 Silverado
Old Aug 17, 2021 | 07:10 AM
ccroasmun's Avatar
Angry PNP 1999 Silverado
I have a 1999 silverado 4.3 blown up and swapping 1999 4.8 into it. My PNP has the 2 connectors 7 pin and 4 pin. The harness I got out of a 1999 silverado automatic has 10 NOT 11 wires going to PNP, purple/white on pin E is not in the harness> Also I found both greens in the fuse block connector but unsure which of the greens goes to which fuse block pin A9 or E3.
Need to know if I can ignore the purple or have to run it somewhere, and how to figure out which green pins out to which connector position.
A pinout for the fuse block connector and the ECM pins the 4 pin connector goes to would be nice.
Thanks very much in advance.
Chuck
Old Aug 17, 2021 | 08:05 AM
ccroasmun's Avatar
Is this supposed to be all Camaro - Firebird. If so sorry didn't realize, still any help would be appreciated.
Old Aug 17, 2021 | 08:51 AM
MaroonMonsterLS1's Avatar
purple is starter relay voltage supply.
Only gives power to starter relay in P or N
as for the green...trace with a multimeter and check which is which. Or, hook em up one way and if the reverse lights come on in park but not reverse...you'll know you have them backwards
https://cpt4l60e.com/wp-content/uplo...ety-switch.jpg
Old Aug 17, 2021 | 09:59 AM
ccroasmun's Avatar
So I can forget about the Purple? Leave it hang?
Old Aug 17, 2021 | 11:08 AM
ccroasmun's Avatar
Oops wasn't thinking, your saying Park, so this purple needs run correct, does it go to the fuse box connect, I think that is C1
