Gear Vendors / Speedo question
"If you were getting a GV, you don't need to get a speedo gear/vss for the th400 - see I could have saved 100$s if someone told me this - as you simply connectthe stock speedo wiring harness to the GV speedo plug (which is a stock gm speedo gear, AC delco package at least) and then you splice the electronics together."
Is this true? What speedo kit do we need for the Th400?
