Can I put a (ISS) on a 2004 4L60e pump?
Old Nov 12, 2021 | 05:33 PM
MaterBater's Avatar
Default Can I put a (ISS) on a 2004 4L60e pump?
Hello, I have a 2007 Chevy Silverado Classic and I’m trying to rebuild a 4L60e (4KCD) to put in it. I have done some research but I regret that I didn’t before I started the project. Supposedly the 2004 4L60e will not interchange with the 2007 transmission model because the pump needs a (ISS)? Is there a way to add a (ISS) to the 04 4L60 or can I bypass the (TCM / something) to where it won’t look for an (ISS) signal?
Old Nov 12, 2021 | 06:29 PM
vorteciroc's Avatar
No.
The ISS Transmissions use a different Input-Shaft, Stator Support, and Pump, compared to the 2004 Parts.
The 2007 and 2008 Model Year Transmissions are different than any other Model Years.
So you are limited to those two years.
Old Nov 12, 2021 | 06:38 PM
vorteciroc's Avatar
Most of the information in this Article is accurate.
Read the Hyper-Link below:
Link
