4l65e swap slipping gears
I was hoping by now that we (LS1Tech Members) had created enough of a Bad Reputation for Monster Transmission...
That No one would purchase anything from them anymore.
What color is the Body of the large round Electrical Connector that is sticking out of the Transmission on the Passenger-Side?
Grey, Black, or Light-Blue?
And just to be clear... I am referring to the color of the Connector that sticks out of the Case (use the examples in the Image above)...
NOT the color of the external Harness Connector that plugs into the Transmission Connector.
Different Model Year 4L60E/ 65E/ 70E Transmissions can have different Terminal-Arrangements/ Pinouts.
Terminal "A" is not usually a 12V Positive location.
Please reply what Color you have, and better yet...
Take an image of the Terminals inside the Connector (so I can see the Terminal-Arrangement).
Use the Terminal-Arrangement Image below, as an example of what I mean for the Image:
Lock-up should take place in 3rd & 4th only.
Honestly, I wish I would have done more research on Monster. I won’t be making that mistake again.
also, I believe it was ordered as a replacement for a 2001 Tahoe. Not sure if that helps or not…
