Stall recommendation?
2004 mustang
6.0 with 706 heads
stage 2 btr ls cam
.660 valve springs
rocker trunnion upgrade
4l60e with all the good parts
4.10 gears in 8.8
stripped interior
275/60-15 28” tall
150-250 shot of nitrous.
holley terminator
not sure what else is needed. Car would be 75/25 strip over street.
@FTI Converters @Jake's Performance both support the forum and do nice converters
Dalton at FTI
Kameron at Jake's
PTC (dusty bradford)
Tampa Performance (Ryan Jans spec, florid torque converter build)
etc the list goes on and on
A converter builder will be able to give you what they believe to be the best combo based on their understanding of the converter and their experience with other setups similar to yours.
Personal opinion, a 4200 ish stall billet front 9.5" converter will be a good starting point. Stator and pump to suit
Good advice above. Get a good builder to crunch your numbers and set the appropriate tight/loose and RPM settings for your stall. With nitrous in the picture you’ll have to be pretty high to sit on the line with it flowing, as in pedal mashed down and all that good stuff. Hopefully your brakes are up for it too.
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
