Slip yoke length 4L80e
Old Dec 29, 2021 | 01:44 PM
Jimbo1367's Avatar
Default Slip yoke length 4L80e
Hi guys,
I am going to run a 4L80E trans and I don’t know the proper length yoke. In case it matters….. this is going into a 70 Camaro. I plan on running a Sonnax forged 1350. How long should I get? Overall or barrel length?
thanks,
Jimbo
Old Dec 29, 2021 | 03:57 PM
MaroonMonsterLS1's Avatar
which output shaft do you have?
assuming 2wd with no o ring for a fixed yoke, I usually prefer "T3-3-5571HP" if you're going with sonnax variety
Old Jan 7, 2022 | 02:10 PM
Jimbo1367's Avatar
Thank you Sir
​is there a bad side of running the shorter version? I think the barrel is about 3​​​​ inches. I do know the one Summit racing sent me was shorter that the one you gave the p/n for.
should I return the short one and get the one you listed?
Old Jan 7, 2022 | 03:26 PM
no it should be fine as long as you have the right length driveshaft and good spline engagement
multiple thousand hp through the short yoke has been done no problem
Old Jan 8, 2022 | 01:43 PM
Jimbo1367's Avatar
Thanks man! I ordered this while driving home from work so I wouldn’t forget. Lol. I originally wanted to measure the th400 o e that I pulled out of my car.
thanks again
jim
