4l60e case bushing failure...
Was there a reason why they show it replaced from the inside? If it matters, it's a 2007 4WD case. I couldn't find any lip so I think it may not matter which direction it gets installed from, as long as the notches are facing inward and about 7 & 1 o'clock(s). Anybody?
I now worry that it might end up in the extension housing like their video, so I'm thinking of knocking it out AGAIN and reinstalling it with a few drops of red Loctite, just to be more "worry-free." I don't have another one, so I'll be reusing it (it was a new bushing that was pushed out with the correct size driver.) The trans isn't fully assembled yet. Please let me know what you think.
Thanks everybody!
If you want to laugh hard, watch his son trying to act like his dad and dissasemble the 4l60e and while trying to sound professional, he calls parts with some weird names ahahha. /watch?v=WRgrntxaJ58&t=579s
I've found only one guy who uses like 1/3 of your groundbreaking mods that you shared and it's "
Express Auto & Transmission David Lee". I bet he took the info from this forum.
I like watching his 4l60e family videos, he disassembles them in 10-15 minutes. I don't like the use of Z-Paks--that's all he seems to use.
He had a good mod for blocking the TCC--he takes the spring out and puts a checkball in, then the spring, then another checkball, and you now have a blocked solid on/off. Don't need spacers, don't need brake line pieces, etc.
So back to my bushing... are you saying don't put the unused but pushed out with #71 bushing back in?? order another bushing? don't put it in with a few drops of red Loctite at like 3-6-9-12 o' clock?
Geez, I may have to wait til the 1st of the month... I may have to skip that 300psi gauge... and I didn't get that bypass cooler and 1800-2200 converter yet... I'll be coming up on a year without a running vehicle the end of the month!
TCC valve is easy to block by just flipping the inner valve around on most years. That's it. No spacers or checkballs or anything. Some years require a hair more effort but not much.
I'm saying if you've driven a bushing out...I don't like to re use it.
So if you have an "unused" bushing that got driven into the case...then driven back out...don't use it. Just personal preference. If you're in a bind, some loctite and it would probably be fine. Green preferred but red will work in a pinch.
And holy crap...a whole year to build 1 4l60e?
It's my only ride so everything I need must be delivered... including groceries. I've been living off Walmart groceries at 10 bucks/delivery and Amazon Prime for Poor People.
It's the Transmission from Hell. Many, many setbacks & delays. Broke a Torx Plus on Day 1 of disassembly... had to order drill bits to drill out 3 bell bolts. Wrong pump for the input drum... many parts ordered for Non-ISS only to find mismatch when parts arrived and had to reorder... some Sonnax parts on backorder... shiit like that...
I'll try to find a new bushing... that'll add another week... Thanks for your reply.
Does it matter which direction it's installed, besides the notches pointing inward at approximately 8 & 2 o'clock when looking at it from inside? I mean, can it be installed from the outside? Thanks.
I think I was just as much in awe how fast he gets retainer rings off, like reverse input rings deep inside the bowels of the case...
