4l60e. 4wd need trans info
Old Jan 30, 2022 | 07:39 AM
Au2o's Avatar
Default 4l60e. 4wd need trans info
I need to know if a 93 to96 4wd transmission will fit in my 2002. Both Transmissions are 4L 60e
Old Jan 30, 2022 | 12:38 PM
tayto's Avatar
one piece case vs 2 piece case. input shaft/TC might be different. 93/94 doesn't have PWM lockup & 3-2 solenoid is different, so you will have to figure that out. 95 is a 1 year only deal, TCC is PWM so should work but 3-2 solenoid is different. you can block the 3-2 solenoid in the VB then install the correct sensor so PCM will be happy. 1996 should be the same electrically.
Maroonmonster just helped me with this, but 2002 into 1995...
