Blocking 3-2 valves
Does the Accumulator valve spring effect the 1-2 shift only or the 1-2 and the 2-3?
my GM tech guide say's it affects 1-2 & 3-4.
Accumulator Valve (371)
The accumulator valve is biased by torque signal fluid pressure,
spring force and orificed accumulator fluid pressure at the end
of the valve. The valve regulates D4 fluid into accumulator
fluid pressure in relation to engine torque, as determined by
torque signal fluid pressure. Accumulator fluid pressure is
used to control shift feel during the 1-2 and 3-4 shifts. During
the 1-2 and 3-4 upshifts, the valve regulates the exhaust of
accumulator fluid to help control shift feel.
- A stuck accumulator valve could cause no 3-4 shift, slips or
I'm hoping that @vorteciroc or @MaroonMonster could weigh in on it.
I have a customer complaint of a hard 1-2, 2-3 shift & a normal 3-4.. It got a standard OH with a TransGo Box SK, corvette servo and a .500 boost valve. I did block both 3-2 valves and I do not usually do this on a Daily Driver...
we need way more info here.
What is line pressure
what were orifice sizes
what accumulator setups
etc etc
If there are codes for anything like a MAF or MAP sensor. Or if there were trans slip codes before overhaul that didn't get cleared. Etc...you need to address those otherwise there will be increased line pressure and overly harsh shifts.
sometimes you cant make them believe you until you show them... Today he comes by to see inside. He is a mechanic at a local shop, one of 9 mechanic's there.
