1997 v6 4l60 to 5.3
Old Mar 25, 2022 | 06:51 PM
oklahomahounds's Avatar
Default 1997 v6 4l60 to 5.3
I bought a 4l60e out of a 1997 v6 camaro for my C10 5.3 LM7 swap.
can anyone tell me what kind of torque converter I need now?
I know i need a crank spacer and I already replaced the bellhousing because the old one was cracked
Old Mar 28, 2022 | 11:12 PM
bbond105's Avatar
The V6 bell housing, torque converter and input shaft will not work on the LS engine.
Old Mar 29, 2022 | 07:13 AM
MaroonMonsterLS1's Avatar
torque converter and input shaft can work on an LS
it's not ideal and can be a pain to make sure you get the right mix of parts, but it is definitely possible
Old Mar 30, 2022 | 07:05 PM
Thanks for your response.
could I use a larger 5.7 torque converter with a crank spacer?
