View Poll Results: How many gears does the 4l60e have
3
0
0%
3 with overdrive
6
100.00%
5
0
0%
6
0
0%
Voters: 6. You may not vote on this poll
4l60e transmission not shift right help
Old Apr 27, 2022 | 10:40 AM
Lrocker391's Avatar
Default 4l60e transmission not shift right help
It seems like it's not shifting into 3rd instead will hit rev limiter in second or will act like it's in nutral and not accelerate will just start revving
Old Apr 27, 2022 | 10:51 AM
Edward Stark's Avatar
Your 3/4 is sooooo dead.
Thats the fun part of owning a 4l60e.
Build it. Build it. Seriously, Just build it!
Old Apr 27, 2022 | 01:19 PM
bbond105's Avatar
The 4l60e is a 4-speed transmission with 4th gear being overdrive. When accelerating you should feel 3 shifts and a drop in RPMs once at cursing speed when the torque converter clutch locks up.
As for the issue you are having, in all likelihood your 3-4 clutch has expired and will require a rebuild. I don't think it is an electrical/electronic problem, because for the transmission the make the shift into 3rd gear both shift solenoids are turned off. If the transmission was unplugged, it would have 3rd gear if it were mechanically sound.
Old Apr 27, 2022 | 01:57 PM
tayto's Avatar
i like how this 1 post wonder started a poll. don't think i've seen that before, very original...
Old Apr 27, 2022 | 02:35 PM
The thing i love about this poll is there are 5 votes, and all of them are right.
That shows how informative our forum is and the credits goes to our pro's whos sharing that knowledge.
I wish this forum was a bit more alive because i want more maroon and vorteciroc in my life 🤓🤓🤓
Old Apr 27, 2022 | 03:00 PM
MaroonMonsterLS1's Avatar
I can tell you point blank why our activity levels has dropped off significantly.......
