Trannie 4l60E
Old Jul 6, 2022 | 01:07 PM
08ltzcrew1974's Avatar
Default Trannie 4l60E
I have a 08 needs a transmission will a 05 4l60e work to replace mine that in it now 5.3 v8 ltz crew cab is what I have and the 05 is unknown
Old Jul 6, 2022 | 03:13 PM
mrvedit's Avatar
Moderator
No, the 05 4L60E does not have an Input Speed Sensor (ISS) and your '08 Transmission Control Module (TCM) absolutely requires it.
According to this document even 2006 was a transition year with some '06 having ISS but perhaps not all.
https://www.transtar1.com/TranstarIn...T-P774-001.pdf
Old Jul 6, 2022 | 05:00 PM
Default 4l60e
ok so then if my speed sensor was to go bad then my transmission would not switch gears would be like in park and neutral correct
Old Jul 6, 2022 | 05:40 PM
dixiebandit69's Avatar
More than likely you'll only have 3rd gear and reverse.
Old Jul 6, 2022 | 05:44 PM
Default 4l60e
Yes that's that's I had then only 1st now won't move
