Drag Race Powerglide Questions
Hey what are you guys doing for Bands?
There has been a Clutch and Brake Relining Business where I live for the longest time.
They were doing my PG, THM400 and 4L80E Bands... but have now closed.
I have not looked at bands in the LONGEST Time... I have no idea what to try.
On that note, I keep hearing about a 2 and 5/8" wide Carbon 4L60E Band...
Who offers this?
Who offers this?
Whatever It Takes
N74020BAHP
Price: $61.50Core Charge: $0.00
Available: 1
Band, 700R4/4L60E/4L65E(2 5/8" Wide)(W/Carbon Lining)1982-Up (Hi-Perf Racing)(" New Alabama Bands" )
Thanks for that!
Yeah... all the distributors have been pushing 'Bama Bands for a while now.
I might experiment some...
I have been mostly using Raybestos for Friction Elements...
But all I see is Kevlar Bands, and I tried many years ago.
They suck... the ONLY benefit to the material is that it is VERY difficult to burn.
The Stock (Late 60E) Band is excellent up to a very significant point.
I was using Alto Carbon Bands (I do not use Alto otherwise) in THM200-4R, THM700-R4, and 4L60Es...
But some are discontinued, and others are just hard to find.
Here is my tentative parts list.
Sonnax Reverse Clutch Pack Retaining Ring
5 ea. 0.100 in. Thick Reverse Clutches
5 ea. 0.070 in. Thick Reverse Clutch Steels
Sonnax High Clutch Pack Retaining Ring
6 ea. 0.098 in. Thick Alto Red grooved High Clutches
6 ea. 0.070 in. Thick High Clutch Steels
Sonnax High Clutch Hubs 28304
4L60e Pump Bushing in High Clutch Drum
Sonnax Oil Pump Gears
Sonnax Stator Support Shafts 28154S if needed
Sonnax Pump Thrust Bearings 56241
Sonnax Band Adjustment Screw
Sonnax Servo Piston Kit 28821-10K
Summit Racing™ Input Shafts SUM-700324
BTE 1.80 9310 straight cut gears installed in stock carrier and output shaft
Sonnax Rear Sun Gear Bearing Kit
Sonnax Ring Gear Stabilizer Kits 28510-S2
Sonnax Output Shaft Supports 28080K
Planetary pin rebuild kit with washers and bearings for 1:76 and 1:80
SFI Approved Bell Housing. I don’t think I can use a flex plate shield and keep the top bolt hole in the bell housing. I also have a case that is broken that I can put to use.
Band I hope to have a good stock Asbestos band in one of my cores
Sonnax Shift Levers 28431-05K
Coan Racing COA-12020 - TRANS BRAKE KIT W/ADJUSTABLE PRESSURE REGULATOR (STD. PATTERN). I have an old TCI brake that that is in rough shape and needs a new solenoid. I also want to try Coan Racing’s adjustable PR valve. By the time I buy the PR valve and a solenoid the brake is only $235 more.
Deep, Aluminum 2 qt. Pan and filter adaptor
Tilton Transmission Oil Cooler Pump 40-524
Rebuild Gasket and seal kit
Bushing Kit
I think this is everything
Bushing Kit
And machine rear of case to accept a roller bearing in place of bushing
I did purchase the HP Books PowerGlide Handbook by TSR (Carl Munroe) and in does go more in-depth in its coverage of modifications. It also seems to be more up to date.
I do have a question though. Why is the Powerglide high performance industry pushing Kolene steels in both clutch packs? You really have to search to find just a plan steel.
Who offers this?
Who offers this?
Summit Racing™ Input Shafts SUM-700324 Not a bad choice, but If your converter has a bushing in it, you could get some extra cooler flow with a shaft that doesnt have the front bushing land. and 300M isn't much more for the added insurance.
Tilton Transmission Oil Cooler Pump 40-524 Little over kill in my opinion for a bracket car unless you're double entering the car and going rounds. But extra cooling is never a bad idea
Bushing Kit
Bushing Kit
-Dalton
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
Thanks Dalton. Don't all turbo spline input shafts have the front bushing land on them? My plan was to run the shaft without the bushing in the pump. Will this cause a problem or is there a better way?
I have seen FTI steels in Summit's online catalogue and plan to get them from there.
Brian
Brian
Sonnax Oil Pump Gears-Check the clearance and condition of your stock gears. If they are in good condition there is likely no need to replace them
Sonnax Stator Support Shafts 28154S if needed If you are using a converter with a bushing in it you don't need a stator with bushing in the front. This is a nice upgrade tho if the stock stator shaft looks worn.
Sonnax Servo Piston Kit 28821-10K I have great success with just the supported servo kit 28821-20K. But if you want the one you listed that's a fine choice too
Summit Racing™ Input Shafts SUM-700324 Not my first choice but will work
BTE 1.80 9310 straight cut gears installed in stock carrier and output shaft I can't express how strongly I recommend against this. Just get a nice gearset with nice output. The output on the stock are weak. The carrier is fine but why chance it with a broken output.
Sonnax Ring Gear Stabilizer Kits 28510-S2 I do not believe this kit works with anything other than the sonnax gearsets.
Sonnax Output Shaft Supports 28080K Stock output/governor support here is the way to go. Use a block off plate if your transbrake requires it. The roller bearing isn't the best option here imo
Band I hope to have a good stock Asbestos band in one of my cores This is a great choice AS LONG AS it's never seen water intrusion
Bushing Kit
Bushing Kit
Bushing case, gov support, and tailhousing. Done properly this offers superior support and negligible drag vs rollers. the key work there is PROPERLY. I can show you pictures of units with 100's of runs at 1500+ hp that have no discernable bushing wear. Someone justify the rollers to me.
Also...the rollers affect the lube circuit and play with how the rest of the unit gets lubed
Thanks MaroonMonster I will upgrade the input and output shafts and scale back in the other areas as suggested.
Is it okay to use a turbo spline input shaft without the stator support bushing in the pump? Will this cause a problem or is there a better way? All of the turbo spline input shafts that I have seen all have the land for a bushing.
Not to hijack a thread but I am looking at doing a similar build myself. Going to probably copy this list. What input shaft is a ringed shaft considered failure prone? What would be recommended for a drag and drive type deal. Also what would change for a decent nitrous shot through a stock case powerglide? 250-300 shot with room to grow. This list and thread has been informative.
In regard to using Roller-Bearings for the Case and the Rear-Pump/ Governor Support, Tail-Housing...
I only recommend doing so by Drilling and Tapping Set-Screws with an Orifice Drilled through, to reduce Lube Oil Flow.
I really also see no ET or MPH increase from the Roller-Bearings... so I do NOT usually bother with them (Except in some uncommon situations).
I will just go with stock bushings in those areas after seeing the recommendations.
Thanks, MaroonMonster, Dalton and Vorteciroc. I think I now have the info needed to move forward. There’s nothing left to do but order parts and get busy.
How does this input shaft look?
Coan Racing COA-12800 - 300M ALLOY INPUT SHAFT, 12 7/8" (FITS 1.69, 1.76, 1.80, 1.89, 1.96, 2.03) - Powerglide - Components
Coan Racing
Part # COA-12800
Coan Racing
Part # COA-12800
That is powerglide spline not "turbo spline"
you will need the 12802
It has a bushing journal for the front of the stator, but if you use the proper converter, you'll have no issue running that shaft with the stock stator tube and no bushing.
As for gearset, I strongly recommend the sonnax gearset. In my opinion it is the highest quality gearset on the market. The additional cost is worth it IMO
Brian
Brian
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
