Corvette 4L60E dipstick
Old Sep 10, 2022 | 11:44 AM
CutLS's Avatar
Default Corvette 4L60E dipstick
I have a 2000 LS1 and 4L60E from a Corvette in my 72 Cutlass. The trans has a truck input shaft and bellhousing with a Camaro/truck breakaway TCI converter. Since it was in a Corvette, it has the deep sump (bump) style trans pan with the fill plug on the side for checking the transmission fluid level. Would I be able to install a truck pan and filter and drill a hole to install a Lokar style flexible dipstick tube? The transmission is going to have to come out sooner that later because my transmission fluid temp is getting into the 240s at the track and my converter is starting to shudder, so it would be a perfect time to do that.
