700R4 pump
Old Oct 25, 2022 | 11:14 AM
lowrider's Avatar
Default 700R4 pump
On 700 rebuild, pump drops down to the rubber seal and stops like it's sitting on something. pump is aligned and fits otherwise.
I pulled out the input and reverse drum assembly and dropped the pump into the drum. There's about an 1/8th inch gap between the drum and the plastic pump thrust washer.
Old Oct 25, 2022 | 11:46 AM
MaroonMonsterLS1's Avatar
its not going to fall into place
it's a seal...it will have tension
you should be able to lube the seal and gently push the pump in with your thumbs. but it won't just fall in
Old Oct 25, 2022 | 12:34 PM
lowrider's Avatar
I realize that, It seems something is jamming it from pushing it into place. I'll check again to see if the pump halves are aligned.
Old Oct 25, 2022 | 01:26 PM
2BFAST's Avatar
Might check your rings on the stator. If one isnt sized right it wont go down in the rev drum. Try putting your resizer on them for a while then try it
Old Oct 26, 2022 | 07:15 AM
lowrider's Avatar
Junk. found a crack on the front of it. I wonder if its out of round.. I tried lining it up with bolts loose and no seal. No go.
