4l60e shift flare ?
Old Nov 5, 2022 | 11:19 PM
slowtransamws6's Avatar
Default 4l60e shift flare ?
I have a 2000 firebird with a 4l60e auto. I’m getting this drop in rpms while wot, I can punch it around 40 and the rpms will rise then drop for a second… Feels like a shift flare. It was slipping about a week ago but I changed the fluid and filter which seemed to get rid of the slip but it has acted strange ever since. there was a bit of metal on the pan magnet but I’ve seen worse, I have a video of it right here. Also if I floor it from a stop all the gears shift fine no flares/slipping
https://youtube.com/shorts/KbZXN86arSw?feature=share
Old Nov 6, 2022 | 06:48 PM
jetech's Avatar
Veteran: Air Force
RPM dropping would not be slipping. Hard to tell ...could it be the torque converter locking up and then unlocking? Maybe move this post to the automatic transmission section
Old Nov 7, 2022 | 10:56 AM
performabuilt's Avatar
LS1Tech Sponsor
I can't tell much from the video but you would normally see an rpm drop on a shift. Or as mentioned the converter could be locking momentarily that would be a tuning issue,
Flare would not be a proper description of what you are seeing.
Frank
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 8, 2022 | 01:02 AM
Frank
I’m guessing it’s something with the converter. Before I changed the fluid it was 2 quarts low on trans fluid and was slipping, which the dealer I bought it from said fluids were all changed… but it was pretty dirty. I’ve had multiple shops try to Diagnose the issue but with no luck.
