4l80e reverse issue
Here are the 8mm head bolts I removed from the PMS: https://imgur.com/a/NF6vQRq
So the longer bolts that hold a stock 3/4 accumulator onto the valve body are 08675533 and have an UHL of 2.5", so ditch those longer ones once you confirm that the UHL is 2.5" for those longer ones.
The bolts that you want to secure the pressure manifold switch to the valve body have an 8mm head are m6x1x55 and are part number 8676222
For reference, the valve body bolts with the 10mm head are m6x1x55 and part number 11515262
So get 3 of these: https://www.rockauto.com/en/parts/ac...ody+bolt,18158 from your supplier of choice.
FYI rock auto code for 5% off: 203171354183710334
Rock auto shipping sucks as of late, so maybe someone has some that they can just ship you. Or you may be able to secure some locally at an ACE hardware or Fastenal.
I adjusted the braided dipstick to be the right depth. Unfortunately it is super hard to read. I can't tell if it is over full or not even on the stick. Fun stuff
anymore I shy away from flexible tube dipsticks unless there is no other option.
also some well-placed P-clamps will help get consistent fluid readings
