LS swapped 69 Firebird 4l60e issues
Old Jan 17, 2023 | 06:15 PM
vorteciroc's Avatar
But you can apply the Reverse-Input Clutch when the Band is off, and the Forward Clutch is applied!
Anyone want to guess which Gear the Transmission will be in?
Old Jan 18, 2023 | 08:01 AM
MaroonMonsterLS1's Avatar
I've covered this in another thread
And I have something cool coming to market regarding this
It will be in 3rd....with similar (or more) clutch capacity than a th400 direct clutch
Old Jan 18, 2023 | 10:48 AM
2BFAST's Avatar
Smile
Patiently waiting.......
Old Jan 18, 2023 | 11:56 AM
I'll test that patience
Old Feb 22, 2023 | 01:29 PM
goodtimes44's Avatar
I wanted to circle back here and share the long sought after fix to my issue. I tore apart the 60E that I rebuilt multiple times and was dumbfounded that I couldn’t find the smoking gun. So I purchased a Performabuilt level 2 trans and installed it only to have the same damn issue. So I knew it was tune related and also that the trans I rebuilt myself was probably just fine. When I got the LS2 from the salvage yard car I was able to get the E40 ECU and the dbw pedal. I couldn’t find the TCM from the car so I bought another T42 TCM from another 2005 corvette on eBay. Where I goofed was thinking that it would tie right into my setup (HP tuners read it and I was able to tune it), however I didn’t reprogram the TCM with a tech 2 and pair it to the ECU. I purchased a VCX Nano off Amazon and paid the $40 through ACdelco TDS for SPS programming and I found only 1 of the 4 links to the ECU was working and the others said uncalibrated. I did a replace and reprogram for the TCM and now my car drives and shifts perfectly! So I hope this solution helps anyone in the future who runs into the same or similar issue, and the importance of pairing the ECU and TCM.
Old Feb 22, 2023 | 04:51 PM
bbond105's Avatar
Thanks for reporting back.
