460le tcc cirquit
in this manual a "tcc signal valve" has line pr. and 2nd clutch pr. as inputs and produces a tcc signal that modulates tc feed fluid pr. (from prv/boost valve) in the tccv.
i was thinking the "regulated apply valve" is modulated by afl pr. from the tcc-pwm solenoid, has line pr. as input and sends regulated apply pressure to the tccv to modulate the tc feed fluid pr.
conclusion: tcc signal valve = regulated apply valve. yes?
* could anybody point me to "later version" manual?
(im trying to educate myself, maybe im just confused.)
https://www.performancetrucks.net/fo...al-pdf-418823/
what im curious about is the regulated apply fluid loop through orifice #8 back to the reg apply valve. there is not a description of the orifices in the manual, if im not missing something. what purpose does this have? damping of the cirquit? (i understand there a many valves set up like that, i just dont know why.)
