Manually shifted automatic transmission or automatic shifted automatic transmission
Old Mar 22, 2023 | 08:40 AM
Yoji h 123's Avatar
Default Manually shifted automatic transmission or automatic shifted automatic transmission
Which do you guys recommend manually shifted automatic transmission or CO2 or air for drag racing?
Old Mar 22, 2023 | 09:20 AM
bbond105's Avatar
CO2 or electric solenoid on shifter.
Old Mar 22, 2023 | 09:59 AM
Yoji h 123's Avatar
Okay thanks
Old Mar 22, 2023 | 10:03 AM
Yoji h 123's Avatar
How much of a time difference is there in manually shifted automatic transmission and CO2 shifted automatic transmission?
Old Mar 22, 2023 | 03:30 PM
bbond105's Avatar
No time difference at all as long as you don't miss a shift point when shifting manually. If bracket drag racing an automatic shifted transmission will always shift at the same time every pass, helping you run consistent times.
